Stock Shocks.. What to buy..
are Monroes really that bad??
ok.... so I just bought Monroes for all 4 corners because Im lowering my car (Sportline Ebiach) and everyone recomends to replace the stock struts and shocks when doing this. Did I just waste my money or will they work? Im not going autocrossing anytime soon (never). I just couldnt justify to myself spending over $300 more for the same parts. Keep or return
Sportlines are arguably the worst springs you can buy for the fbody(literally sits you on the bumps stops), and you are mating them with some of the worst shocks as well...
Generally speaking when it comes to suspension (for our cars atleast, I can't speak for all cars) you really get what you pay for. The cheapest stuff is dreadful, like buying really used old toilet paper.
Its "recommended" to replace your shocks (our cars don't have struts, just shocks on all 4 corners) when you get a lower, stiffer spring because the stock shocks (and the cheap "OEM" replacements, like above) struggle to dampen the stock springs none the less a stiffer spring with less travel. This leads to jarring, jittery ride quality while also being floaty, bouncy and loose. You upgrade to a sport/performance shock because they can control the higher rate spring because they have better/more aggressive valving.
Many people "shrug off" the shitty truck-like ride quality these cars have from the factory and think "its supposed to be like that", when that couldn't be further from the truth. The reason its like that is because of the shocks not being able to dampen the car correctly. You can have significantly better ride and handling with proper dampening.
Sorry I have to lol though... Do a search.
SLP Bilsteins. Might want to return the Eibachs while you're at it too...
But since it's an SS, ya might want to wait a bit and save for something better like Konis and say Strano springs if you really want to lower...
lol, I dont blame you for laughing.. I'd rather be told its crap then going through the trouble and money to install it and regreting it. I dont want to buy and install cheap parts but I really cant afford the best (cant blow my money on this SS like I did with my last one on my sig. ). Can you or anyone recomend a better quality brand without breaking the bank? Thanks1
Me personally I would go with some Koni 4/3s with your stock springs, or if you want a little drop use the lower front perch on the konis and the heater hose mod in the rear.
Thanks everyone for your advise, JD AMG and libertyforall especially. I spent all day yesterday researching the forums and internet and decided that Im going with the best even if it takes a little more time to save up to get it. So the shocks has been returned and the Sportlines will be in the Clasifieds before days end today. As far as the shocks, Alot of positives with the Koni's and for Springs Im thinking Strano or Hotchkis. Im looking for a drop so Im hoping for the best of both worlds, to be lower with an awsome ride quality. Anymore suggestions is highly welcomed. I added pics, the car sits on 18's.
#33
If money allows, I doubt you'll be disappointed with Strano/Koni. I have the Koni 4/4's on stock springs and it's amazing how much better the car handles and how much more control there is than stock. There are also a ton of reviews on here with the ride/handling with Strano springs.
How about the KYB GR-2's....??
#35
LS1TECH Sponsor
Bare minimum shocks... KYB AGX, preferred minimum shocks SLP Bilstein. Koni's are the best choice. GR-2's are just stock type replacements, valved for stock springs. They are better than worn stock shocks, period--but not meant for this use and not build exceedingly well either.
__________________
#36
#37
LS1TECH Sponsor
If you have any questions please feel free to call me. I have some SLP's in stock right now, but we are starting to run low (just an FYI) on this batch.
__________________
#40
What the hell is it with all the vaginas that come on this forum lately? You give them good advice and they whine and cry about it if you don't give them the answer they want to hear.
Ok then.. go buy some Monroe's from pep boys. That should do the trick *pat on the back*
