Strange Handling issue...diagnose? While going about 70kms an hour - put it in neutral, and took the foot off the gas, slowed down ... I felt my car pull left. If I had let the steering wheel go - it would have veered right. Then - out of nowhere - it started pulling left. From right to left. No corrections, no input. I pulled over immediately - as I thought I had a flat tire. No flat. Diagnose? I drove home with the problem not repeating itself in the initial severity - but quite noticeable. Obviously I don't want to drive this thing until I figure it out... MODS: solid motor mounts... LT / Catback... SFC... Adjustable panhard... |
Loose lug nuts, loose suspension pieces, bad tie rod(s), bad lower ball joint(s), worn wheel bearing hub(s), severly degraded bushings. These are all possibilities. |
© 2024 MH Sub I, LLC dba Internet Brands
