Wtf i still have wheel hop
After installing Lakewood LCA's and a Edelbrock Panhard bar (adjustable) whats going on?
1-2 goes like BOOM BOOM BOOM and I have to feather it out
What do I do next?
What do I do next?
LS1Tech Premium Sponsor
I would try a set of relocation brackets first as a more cost friendly mod then if they don't correct it a torque arm is in order...
Hello,
I agree with everyone above. The lower control arms are a great start but won't always cure all the wheel hop issues. The panhard bar is a great item but like mentioned isn't designed to cure any wheel hop issues.
I would also recommend a set of relocation brackets for your next step, they are inexpensive ($89.99) and make a very noticeable difference. The torque arm is also a great item and eventually a great upgrade but is a bit more expensive so it depends on what your budget allows.
Here is a link to the UMI Relocation Brackets- www.umiperformance.com/2012
I hope that helps!
Ryan
I hope that helps!
Ryan
www.umiperformance.com/2206
www.umiperformance.com/2205
If you have any questions please ask. Thank you!
Ryan
LS1TECH Sponsor
Installing a trans mount TA isn't hard, there are a just a few little tricks to it. Again, something I try and let my customers know about. Just one of those things that you don't get from vendors who only sell parts or ebay stores..... Service is part of the sale with some places--more often it's only about the sale with many shops. Can't say I blame them, I get a lot of tire-kickers wanting the info they can't get from their bargain shops. I've had to stop being so open which is pretty sad, but it became the only way to protect my business and the stuff I've had to learn.
I use a UMI Trans Mount TA on my Camaro, and in fact I use that TA most often, and if folks want to get the mounting off the transmission we then add a TA Relocation bracket.... Either way is IMHO a superior setup to a tunnel-mount arm for a number of reasons.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
