Large install ahead! w/ PICS
So I'm starting with my nearly stock 2000 A4 WS6, only mods are a lid and a line lock (used for fun pretty much exclusively, not a drag car)
Where the story begins, driving normally on my way home and decide to stomp on it. A4 downshifts to 1st around 25mph and a loud SNAP and rattling sound. So after I get the car home I get it torn apart... sheared torque converter bolts, damaged oil pan, flexplate and torque converter have the holes mangled.
Fast forward to now, decided to go aftermarket, bought a 2nd car and put the t/a in the garage
This is my build list, 90% of which is already purchased.
Interior:
93-02 Firebird & 97-02 Camaro Autometer Triple Pillar
Auto Meter Phantom Electric Trans. Temp 100-250 F
Auto Meter Phantom Series WideBand
Auto Meter Phantom Mechanical Oil Pressure 0-150PSI
Corbeau LG1 Seats
Momo Jet black steering wheel w/ hub
93-02 Firebird/Camaro Auto Trix Passenger Window Fix Kit
Viper 5902 Responder HD Color SuperCode SST 2-Way Security and Remote Start System
Exterior:
19x9 Tork Imagine with 275/35/19 KDW's
BLS Low Beam HIDs
Engine/Exhaust/Electrical:
Power Bastards Alternator (hate the dimming at idle on my current alt..)
Texas Speed & Performance - Pacesetter Headers & TSP Cat Y Pipe Combo
Hooker Catback 16811 Exhaust
Truck Starter w/ long bolts
SFI Flexplate w/ ARP Bolts
160° Thermostat
MSD 8.5mm Spark Plug Wires
Vette o2 sensors (for the longtube headers)
Transmission/Driveline:
B&M Cooler 14,400 BTU
Circle-D 1C torque converter
Neapco driveshaft U-Joints (stock ones were a little rough upon inspection)
New GM rubber trans mount
Suspension/Chassis/Steering:
UMI 3-Point Bolt-In Subframe Connectors
UMI Shock Tower Brace
Spohn Solid Motor Mounts
UMI On-car Adj Ctrl Arms Poly/RotoJoint w/ HW kit
Strano Performance Red FAYS2 Watts Linkage
Strano Performance 35/22mm Hollow Sway Bar Set
Strano Performance Koni 4/4 Sport Shock Set w/On-Car Single Adjustable Rears
UMI Full lengh adjustable Torque Arm & Hardware Kit & Relocation Bracket
Strano Performance Parts Lowering Springs
Turn One power steering pump w/ pulley
Blain Fabrication Reinforced Front Swaybar Mount
UMI Performance Heavy Duty Billet Aluminum Front & Rear Swaybar Brackets
UMI Performance Driveshaft Tunnel Brace Long Tube Header Clearanced
Brakes:
Kore3 C6 Z06 Front Brake Kit
RPM Speed Stainless Steel Brake Lines Rear
Any tips you guys have for me on the install of any of these items to make it easier/avoiding cursing/throwing tools/punching walls, etc
Any and all criticism is welcome
My overall goal: canyon carver and weekend/sunny day ride
I know u guys love pics, so here are a few
Interior:
Corbeau LG1 Seats
Exterior:
BLS Low Beam HIDs
160° Thermostat
Brakes:
1 Post
Yeah same here, with school and tests every week or other week the things i need or want to do just keep building up. Need to party less on the weekends and work on the car more for a while..
