Clearance with lowering springs?
I want to know about your setup; shocks/spring/tire size & wheel and if youre having problems with clearance..
I've been into cars that the tires touch the fender/wheel well and I really hated it!!
I'm in the process of shopping shock and springs. Bilstein/Konis/Strano springs or stock..
My tires are 285/35R18 nitto's 555 rear and front 245/40R18..
Johnnystock, how do you like those 285/35/18 555r i assume? I
have BMR 1.25 springs and will have 18x9.5 C5 Z06 on all fours with 275/35/18. Fits perfect. No issues.
C5 Z06 rims, fronts are 17x9.5, 54 mm offset, 275/40/17. Rears are 18x10.5, 56 mm offset, 295/35/18. I just recently installed strano springs. I have no issues at all up front. The rears liked to rub when I take a turn hard, but that happened even before I installed the springs. I just took a hammer and beat the **** out of the inside of the wheel well where it was rubbing. They don't rub at all now even with aggressive cornering. Might remove the 1/8" spacer I have on the rears now
