questions about raising the rear
Im running eibach springs all around. I need to raise the rear about an inch to inch and a half for about a month. Im towing my seadoo. Has anyone used these spacers? Or should I try to find thicker/taller isolaters? My tongue weight is very low but I want a little more room since my rears rub on big dips =once in a while. Or should I go with Airlift bags?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110676363476&ssPageNam e=STRK:MEWAX:IT
OP did that add state thoes were for 70- 90 model GM?
most parts suppliers carry a Mrster Gasket coil spring spacer ( rubber donut which seats under the coil spring cost about 10-20.00) will rase about 1" to 1 1/4 "
Good luck, Johnny
edit :: I looked a specs again, ok they state they will fit sorry I did not see fit before
J.
Good luck, Johnny
J.
