Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird Brake Pad Reviews<br>Review and comparison of top products.
Best Brake Pads
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I know this is a dumb question but i just got a drilled and slotted rotor package with brake pads and the dang brake pads give off brake dust and it covers my ZR1 wheels and looks terrible, please can you tell me what the best brake pads are and where to get them?
i just cant stand it when my wheels have alot of brake dust on them. i didnt drive it but 30 miles and they were covered, idc about performance i just want NO BRAKE DUST
Everyones suggestions here are right on the money.
If you want performance pads (with lots of bite) then you will get brake dust (from semi-metallic or other materials OTHER THAN CERAMIC).
If you are not looking for added grip\bite from your brakes and just want clean and quiet then get ceramic.
Your drilled and slotted rotors will contribute to dust more than blank rotors because they clean the pad (thus creating more dust). Also, while driving in town, drilled and slotted rotors will decrease stopping distance a little because of less surface area mating to the pad.
I have Hawk HPS + (autocross pads) NOT Ceramic and they stop like you would never ever believe!!! Feels like a different car -no joke. They do dust up but i wash my car so often that i dont care.
-my .02
-my .02
Decreasing surface area will lead to slightly higher pad and rotor temperatures. On the street, this can be a good thing as pads often run colder than their optimum temperature for the best coefficient. However, if running street pads on the track (which should not be done), the temperature rise can lead to slightly earlier pad fade.
To the OP: If dust is the PRIMARY concern, go with a better quality ceramic -- like Hawk Performance Ceramic. Those give up the least when it comes to ceramic pads. Most of them give up 15-20% of stopping power right out of the box. If you just want less dust, but still value performance, then you may want to stay with Hawk HPS or other similar iron-carbon semi-metallic compound.
Chris
Your other comments make some sense, but not this one. Contrary to the beliefs of some, reducing the surface area does NOT lead to less brake torque. Actually, if done properly (and few are!), it will lead to MORE brake torque. This is due to the increase in leading edges that the pad sees. Each extra leading edge adds just a bit more pad bite.
Chris
Chris
So Chris... How much for a set of J-Hook friction rings for my 12.20" Wilwood hats?
The projects I'm involved with have no matches for the Wilwood stuff. If you have an AP Racing or Brembo system, I'm sure I could point you in the right direction. Otherwise, you might wish to try a Wilwood distributor or maybe Coleman Racing? You'd be out of luck on the J-Hooks, however, as they are trademark protected.
http://www.essexparts.com/learning-c...ose-brake-pads
That won't give you brands, but will help you find the right combination of pad features when picking a pad. I currently run Hawk DTC-30's on my daily driver, and I can say based upon your goals, don't use these
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Of course, they dust like driving through a coal mine. And how many storefront windows have you shattered with that incredible brake squeal?
Chris
I've tested quite a few of these for Hawk. They have outstanding torque response from cold up to fairly high temperatures (just short of road racing). These are a lot of fun to drive, especially on freeway off-ramps!
Chris
Chris
Can you elaborate on the off-ramps? The dust is more irritating than the noise to me - my polished wheels look like gun metal after just a week. Applying a bit more pressure reduces the squealing, I barely notice it now. Rotors seem to be lasting about 4 months on the street before there's a serious lip, pads maybe 6 months.
But like many track pads, they wear rotors excessively when cold. The hotter they run, the longer the rotors will last (comparatively speaking). Of course, track duty is hard on both rotors and pads.
And when the dust coming off of them is very hot, it will bed right into most wheel finishes, especially clear coat.
Chris
