Doing rotors and pads question
I have rotors and pads comming from Brakemotive for all 4 sides. Great customer service but anyway I was wondering if I can do this job without bleeding anything? When they do it here...http://www.installuniversity.com/ins...sity/index.htm they dont speak of any bleeding. I dont know why I would have to bleed if I dont open any lines. Can I do my brakes like this without bleeding?
Generally all I do when i do rotors/pads is leave the master cylinder cap open and wrap a shop towel around the resovoir, to catch any fluid pushed back out when compressing the caliper pistons. Id say unless you have a spongey pedal after swapping everything you should be ok without bleeding. However bleeding the brakes is really simple and wouldnt hurt anything.
Chris
Take it to the local dealer if you have the cash. A bg brake flush with DOT 4 synthetic brake fluid using a pressurized machine usually runs about $90.
hmm really. Maybee ill just do that. Question though... If I install rotors + pads without bleed, and do the breakin period will it still be ok to bleed/flush AFTER I broke in the new parts? I ask because obviously I will be driving to a shop after I install new parts at my house.
Like I stated before, if you dont have a squishy pedal feel after the swap then if should be fine to drive to the dealer. Just test the brakes at low speeds and give yourself plenty of room to stop on the way there.
As long as your pedal is pretty firm now you can install the rotors/pads, bed them in and then do the flush without issue.
Just for your quick reference and to add some info for others, I've posted our recommended bed in and bleeding procedure below.
Brake Pad Break-In Procedure
IMPORTANT: BREAK IN NEW BRAKE PADS/ROTORS USING THE PAD BEDDING PROCEDURE AS FOLLOWS. PROPER PAD BEDdumDING CAN PREVENT ROTOR WARPING.
The break in procedure is critical to brake performance. The reason for a proper break in is to establish an even layer of friction material deposited on the rotors from the brake pads. It is very important that this initial layer of friction material is evenly distributed. Break in the pads as follows: 5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. Then do 5 moddumerate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot. After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure. After the brakes have cooled to standard operating temperature, you may use the brakes normally.
PLEASE NOTE: ALL VEHICLES ARE DIFFERENT. THE PROCEDURE BELOW IS INTENDED AS A GENERAL GUIDE AND IS NOT A SUBSTITUTE FOR THE VEHICLE SERVICE MANUAL WHICH SHOULD BE REFERENCED THROUGHOUT THE PROCESS. THE IMPORTANCE OF PROPER BRAKE FUNCTION CANNOT BE OVERSTATED! IF YOU ARE UNSURE OF YOUR ABILITY TO PROPERLY PERFORM THIS PROCEDURE – STOP – AND CONSULT A PROFESSIONAL TECHNICIAN.
What is “brake bleeding”? Bleeding the brakes is a process by which fluid is forced through a hydraulic system with the intent of purging trapped air and/or replacing the used fluid with new.
Why should I bleed my brakes? Liquid cannot be compressed which makes it ideal for applications like vehicle brakes where tremendous pressure must be generated. Air on the other hand is compressible and when it is introduced to a hydraulic system the result is a loss of efficiency. As a driver you feel that inefficiency as a spongy or mushy brake pedal. Inefficient or soft brakes are dangerous and need to be bled to remedy the problem.
Brake fluid is also hygroscopic by nature, which means that it absorbs water. Replacing your brake fluid regularly will ensure that moisture doesn’t build up and corrode your lines from the inside out. Rust can also clog the small orifices in the system which can cause stuck calipers, non-functioning calipers, clogged proportioning valves and other issues. Moisture in the lines also poses a problem because of its 212* F boiling point. Brake fluid can easily exceed 300*F during normal operation which boils water and creates vapor pockets in the fluid.
For the above reasons, it is good practice to bleed your brakes during routine brake service and flush the system at least every two years as part of your normal vehicle maintenance. More aggressive drivers should bleed the brakes annually and racers should bleed their brakes before every event.
Please note that you will require an assistant for the bleeding process.
Tools needed:
Nitrile gloves
Safety Glasses
Flare nut wrench
Extra fluid (1 pint to top off, 2 quarts for a full flush)
Brake Cleaner
Shop rags or towels
A length of 3/16” ID hose
A disposable bottle for capturing old fluid
Put on your safety glasses and gloves and refer to your vehicles service manual for the proper lifting and support techniques. Once the vehicle is supported properly remove all four wheels to gain access to the brake calipers. The bleeder screws are always located at the top of the caliper and are usually covered with a rubber cap. Most vehicles only have one bleeder screw per caliper, however some high performance multi piston calipers may have two or more.
WARNING! – BRAKE FLUID IS VERY CAUSTIC AND WILL LIFT VEHICLE PAINT LIKE CHEMICAL STRIPPER. TAKE GREAT CARE TO AVOID SPILLS OR DRIPS AND IF IT COMES IN CONTACT WITH YOUR PAINT AT ANY TIME REMOVE IT QUICKLY AND CLEAN THE AREA THOUROUGHLY.
Before you go any further, locate your vehicles brake fluid reservoir (usually atop the master cylinder) and check the fluid level. Make sure the fluid is at the MAX fill line and monitor the fluid level throughout the bleeding process to ensure it does not dip below the MIN fill line. If the fluid in your reservoir goes empty while you’re bleeding the brakes, it will complicate the process and require a more involved procedure to correct the problem. So pay attention and check it often!
You always want to bleed the lines starting with the caliper furthest from the master cylinder and work your way forward. On most cars the process goes; RR, LR, RF,LF. Starting with the first caliper, place the flare nut wrench of the proper size over the bleeder screw and attach the hose. Secure the waste container and run the end of your hose to it. Now ask your assistant to enter the vehicle and turn the key to the II position (don’t start the car).
A traditional two person bleeding procedure relies on good communication and timing to go smoothly. Instruct your assistant to depress the pedal several times then hold it down. Your assistant should give an audible confirmation once the pedal has been fully depressed. Then open the bleeder screw a quarter to half turn briefly and let the fluid fill the attached hose. If your system has air in it you will see bubbles come out with the fluid as well. The bleeder screw should only be in the open position for a brief moment. As pressure drops the flow will slow down, as it slows close the bleeder screw. After you have snugged the bleeder screw (don’t over tighten!) tell your assistant to release the brake pedal. Stress to your assistant the importance of not releasing the pedal before you give confirmation that the bleeder is closed. Doing so will draw a large amount of air in to your system making your job more difficult. Observing the fluid as it comes out for any sediment or debris will give you an idea of the condition of your brake lines, ideally you don’t want to see any. Repeat the process until air bubbles are no longer visible. If you are flushing your system, continue till the fluid turns clear or the color of the new fluid being used.
Work your way around the vehicle one caliper at a time until all air or old fluid has been purged. Use some brake cleaner and a towel to wipe any spilled brake fluid off your calipers and cover the bleeder screws with the rubber caps you removed earlier.
Do a final check on your fluid level and cap off the reservoir. You can now replace your wheels and lower the vehicle. Be sure to tighten your lug nuts to the proper torque and in the proper sequence (progressive star pattern).
Start the vehicle and while in park/neutral depress the brake pedal. After a couple pumps the pedal should feel nice and firm. Check for leaks at the calipers and if everything looks good perform a couple low speed stops to ensure the brakes are functioning properly.
Congratulations, you now have a properly bled brake system that will provide confident, consistent and reliable stopping until your next service interval!
I was thinking if I was gonna pay for a bleed/flush I might as well just ask around to see what they would charge just to swap rotors and pads. Called Meineke and they want $200 just for that! So I will swap myself its to easy to pay that much and then bring it for a flush somewhere.
Hey thats a sweet SS man.
As long as the master cylinder reservoir doesn't go completely dry you shouldn't encounter any issues with bleeding the ABS valves. If you aren't comfortable bleeding the brakes you can just compress the pistons in (keep on eye on the reservoir so it doesn't over flow) and put it all back together, do the bed in procedure and then bring it to a pro to flush/bleed.
Tools needed:
Nitrile gloves
Safety Glasses
Flare nut wrench
Brake Cleaner
Shop rags or towels
Tools needed:
Nitrile gloves
Safety Glasses
Flare nut wrench
Brake Cleaner
Shop rags or towels
Thanks Adam I just got the shippment this morning btw. Ill post a review for you guys when its done
