Options to protect against removed bumpstops?
Old 05-27-2011, 09:49 AM
LPE 403's Avatar
Default Options to protect against removed bumpstops?
Looking for some ideas....
I want to reomove the bump stops to protect the new 18X11s. Currently sitting on Eibach Pros with Bilsteins. I don't want to bottom out either....cant recall the spring rate for the Pros
Would consider heavier spring as long as it was black...
Adjustable bumpstop that sits inside the spring is a great idea, but dont want to weld on the new rear end...
Any good pics in trimming the current bump stop out there?
Air lift bags inside the spring?
Car is (will be) mainly a weekend street warrior. Ideas and experiences are appreciated....
Old 05-27-2011, 09:05 PM
shorty(98TA)'s Avatar
If it were me Id go with the adj bumpstop that goes inside the spring. If you dont know how to weld proficiently than take it to a fab shop. I cant imagine a weld shop charging more than $150 to install them if you brought all your parts. Or better yet just find a buddy that knows how to weld
