moving right along: finally lowered!
Old 06-20-2011, 06:49 PM
WVws6's Avatar
Default moving right along: finally lowered!
so i bought some used guys off a local car forum. he had to cut the top nuts off on each front strut so i bought some new shocks to go on the front. i don't have a before picture of the rear well up close. i took the pictures in the rain so it's crappy quality. as for the ride, it is much more firm and responsive. overall, i LOVE it!
before:
after:
Old 06-20-2011, 07:20 PM
cnd99hawk's Avatar
Looks good, what setup do you have?
Old 06-20-2011, 07:34 PM
WVws6's Avatar
JMAX springs. about 1.5" drop all around. they were used when i bought them.
Old 06-20-2011, 10:03 PM
cnd99hawk's Avatar
Anything else? I hope your not on stock shocks.. and if you are save up for Bilstein of Koni
Old 06-21-2011, 05:41 AM
WVws6's Avatar
replaced the front struts. the top nuts were competely corroded on to the bolts, had to cut it all off. kept the stock rears.
Old 06-21-2011, 08:59 AM
cnd99hawk's Avatar
Did you get stock replacements for the front? The reason why I ask is because the stockers or stock replacements won't be able to handle the spring rate of a lowering spring. They can barely handle the stock spring specs. As stated before Bilstein (if on a budget) and Koni (if money permits).
Old 06-21-2011, 11:14 AM
WVws6's Avatar
just bought stock replacements. i am going to go with bilsteins eventually. what do you mean by they can't handle the spring rate?
Old 06-21-2011, 11:20 AM
MYSTIC-1SC's Avatar
Nice stance!
Old 06-21-2011, 03:07 PM
rabbit320's Avatar
because you are putting the same and more force on the shock that is now limited in travel even more because of the spring being shorter. the valves will wear out because its distance of travel is changed, and it will not function the way it is designed to function. you need a shock that is meant for lowering, such as (in order of price): tokico blue's, kyb agx's, bilsteins, and koni's. heard good things about edelbrock's adjustables too.
Old 06-21-2011, 07:47 PM
WVws6's Avatar
Originally Posted by MYSTIC-1SC
Nice stance!
thanks man!
appreciate the information. i will start to look up some shocks and review them. get some aftermarket ones.
Old 06-22-2011, 11:10 AM
cnd99hawk's Avatar
thanks man!
It all depends on what your want to do with your car too and will lead to the shock your after. The stock shocks are one of the weakest points on our cars. If you plan on keeping the car spend the extra few bucks and get some quality stuff. Also read this stickies in the suspension section. A lot of good info there and should help you get a better understanding of suspension and may help point you in the right direction.
Old 06-23-2011, 06:10 PM
WVws6's Avatar
thanks for the input! this isn't a drag car. it'll be driven on nice sunny days just to drive it around. might run with a couple other cars here and there but definitekly not modding for performance and quick times!
Old 06-23-2011, 06:18 PM
meine96ws6's Avatar
looks a lot better man
drone's Avatar
A drag car isnt about a nice ride. Your about to ride like a drag car when those stock shocks wear out.
And since when are bilsteins ok for lowering? I thought they would have the same spring rate issue with lowering springs. I have the HD's now but Im stock ride height. Im gonna go to coilovers to lower it.
Old 06-23-2011, 06:21 PM
71novaguy's Avatar
if thats what only a 1.5 lowering kit looks like, Im in. I've been wanting to lower mine. looks good.
WVws6's Avatar
thanks
Old 06-23-2011, 06:52 PM
Chevycrew's Avatar
nice improvement!
