service manual says preferred camber +0.4 ???
in my 2002 service manual on wheel alignment, it says for camber service preferred is 0.4. Does not have a negative sign. And service allowable for camber is "-0.1 to 0.9".
Is that a misprint?
I thought any camber even stock would be on the negative side slightly if not zero.
Although +0.4 is halfway between -0.1 and 0.9 which is the trend of all the alignment numbers in the book. If +0.4 camber is the preferred stock setting, then why slightly positive?
Is that a misprint?
differant strokes for differant fokes, some ppl like a - setting and say that - is better for road racing or fast turning, I like/get great milage running a + camber and + toe
I may not be a 'spert but have been around for quite a long time/still learning
click on my link below for my thinking about auto alignments
and NO I am not looking for work as I retired 4 years ago
Johnny
Johnny
Most cars are setup from the factory to understeer.. They consider understeer to be safer than oversteer, which in most cases is correct. This is a lot of the reason for the shitty specs for front end alignment from the factory.
IMO, your best bet is to set your camber at -.25* to -.50* for a daily driver with a small amount of toe in and maximum caster.. Gives great tire wear and much improves the steering response of the car.
