Synthetic grease for polyurethane lca's?
Hi guys, I just installed UMI lower control arms on my 01 z28. I used a normal petroleum based grease on there and was told by a tech that it will destroy the bushings over time. He said I have to use this special synthetic grease that is hard to find but UMI carries it. Anyone have any input or experience on this matter?? Also I torqued the lcas down to 80 ft lbs when they were supposed to be 72 ft lbs. I am hearing a squeeking whenever my rear suspension goes over any bumps
LS1Tech Premium Sponsor
A regular non-synthetic petroleum grease will break down the bushing with time. We like to use a grease called Super Lube which we carry and I don't think can be found in stores. Now if you are looking for something you can find at your local auto parts store I would use the Mobil 1 synthetic grease in the cartridges. I would remove the lower control arms and take the bushings out and clean all the old grease out and use some that will work well with the poly-urethane bushings. This will probably take car of the squeek you are currently having. Also the extra 8ft lbs of torque is not going to hurt the bolts, they are a pretty large bolt and can take some torque.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
