Front Koni install problem
So today, like right now I went to check them and I decided to take them off to inspect them and I found out that the shock/spring assembly was LOOSE! the shock mount on top broke off. When I installed them last time I bought brand new Monroe shock mounts to be "safe" but I guess they were crap.
Now im getting GM mounts and I just wanted to go over how to properly install the fronts.
I know I have to put the flat washer first and then the shock mount. Now, how much thread on the shock shaft do I have to see to know the shock mount is completely down and ready to put on the top nuts ?
I just want to make sure I put the nuts all the way down and get a good tight fit.
I appreciate any help guys
You are using the part that goes on top of the shock mount as well (dog biscuit looking isolator part), right?
https://ls1tech.com/forums/suspensio...ts-needed.html
Without the isolators, as I understand it, the shock mounts break. Pretty much what happened to you.
I suspect many shoddy shops who don't do good work, don't use them either and then people have repeat problems...
So I dont even have this plastic isolator you talk about on the bottom perch.
Is there a part number for that ?
I looked on autozone.com and rockauto.com and I couldnt find it.
