BMR Launches New Product - Xtreme Anti-roll Bar (XSB001, XSB002)
Old 11-11-2011, 03:18 PM
BMR Tech's Avatar
Talking BMR Launches New Product - Xtreme Anti-roll Bar (XSB001, XSB002)
BMR Suspension
Xtreme Anti-roll Bar for 3rd and 4th Generation F-Body
Reduce torque steer and improve launch traction in your 1982-2002 F-Body with an Xtreme Anti-roll Bar from BMR Suspension. This newly designed 1-3/8” tubular rear sway bar features 2 adjustment locations that range from 1013% to 1632% stiffer than the OE sway bar. This kit includes a lightweight anti-roll bar, bolt-in axle mounting braces, bolt-in frame mounting braces, high-durometer polyurethane mounting bushings, and double-adjustable spherical bearing end links. A BMR Xtreme Anti-roll bar (XSB001) will decrease body roll and dramatically increase the launch stability in your 3rd and 4th generation Camaro or Firebird. Available in red and black hammertone powdercoat finishes. Installation time of 2-3 hours.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
Old 11-14-2011, 10:22 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Keep 'em coming! Glad we're finally able to bring this out.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-15-2011, 01:40 PM
GT_EATR's Avatar
What all would I need in order to fit an Anti-Roll Bar on a M9 rear end under my 1998 Z28...I believe it has 3" axle tubes..Would anything else need to be changed?
Old 11-15-2011, 01:57 PM
BMR Sales2's Avatar
As long as you have sway bar mounts welded to your M9 the newly designed BMR anti-roll bar will bolt right up. The back brace on the M9 will get in the way of our bolt-in sway bar mounts. If you do have the back brace and you dont have the sway bar mounts you can weld on a set of our sway bar mounts and the anti-roll bar will bolt right up.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Old 11-17-2011, 10:29 AM
99 PROBLEMS's Avatar
do you have any pix/video of the bar installed???
Old 11-17-2011, 10:36 AM
BMR Tech2's Avatar
Well we had them on our website, but then we had an issue with the site on Tuesday and it looks like the pictures were lost. I'll try and get this fixed and post pics ASAP.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-17-2011, 10:53 AM
Nowhereman's Avatar
This will bolt up to a stock rear end without mods?
Old 11-17-2011, 10:58 AM
BMR Tech2's Avatar
Yes, XSB002 will bolt right up to the car. You must drill two holes in the inside of the wheelwell, but that's it. No other modifications!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 02-12-2012, 03:59 AM
LS2Ttype's Avatar
dont put that on a "street" car
Old 02-12-2012, 09:22 AM
HioSSilver's Avatar
Does it transfer noise? Make the rear to loose?
Old 02-12-2012, 09:36 AM
JD_AMG's Avatar
Its a 35mm rear bar, thats absolutely ridiculous, and thats the same size of the largest front bar available (actually I think you can get a 36mm front bar, but still). This is a strait up drag bar and will have your rear riding very rough, and cause major oversteer.
Old 02-12-2012, 10:05 AM
tillery's Avatar
Its why BMR description is for straight line performance for this(Drag racing).
Old 02-13-2012, 08:19 AM
BMR Sales2's Avatar
We have quite a few guys who drive there cars regularly on the street without any issues. As long as the car is driven reasonable with it you can easily drive this on the street.
It will transfer some additional noise because the anti-roll bar is solidly mounted to chassis. The rear bar is super stiff so when driven hard in a corner it will cause oversteer. As long as the car is driven reasonably you can easily drive it on the street.
We definitely state that this is a drag race anti-roll bar and is by no means a bar for any kind of handling.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 03-01-2012, 08:59 PM
TWS
TWS's Avatar
I have begun installing mine and drilling those two holes is... so far... kicking my butt.
What drill do you guys use? Must be pretty small. There is no clearance for my Skil drill, so I bought a 90* angle attachment... still no room to get a clear straight run at it. I drilled carefully centered pilot holes to then go to the inboard side and finish the holes from inside, but there is also not enough room for my drill coming from inboard. I got the 90* attachment up in there and still no amout of twisting or turning would give me a good straight run at the hole.
I am going to pick up a Unibit tomorrow since it is only about 2" long from the drill chuck and see if that helps, but if you can show me a better solution or where to buy a really small yet powerful enough drill I'd appreciate it.
Old 03-02-2012, 09:49 PM
TWS
TWS's Avatar
I'm back in business. Unibit and 90* attachment FTW.
Old 03-03-2012, 09:07 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I got a 36.5 mm Hotchkis front bar on my SS.
Old 03-03-2012, 09:08 PM
So this is a drag bar only???
Old 03-04-2012, 07:33 PM
TWS
TWS's Avatar
This is my second car with the BMR Xtreme, but the other car has the older style one with the weld-on brackets - but that makes no difference. It sees a good bit of street time and there is no problem as long as you remember what you are driving.
I often cruise out to street meets with that roll bar out back, NO front sway bar, DR's out back and skinnies up front. Goes without saying that I don't take highway off ramps aggressively. I keep in mind which car I am driving so I never have a problem.
Old 03-05-2012, 11:43 AM
BMR Tech2's Avatar
Thanks for your input. It's good to hear from more street ship customers who are using them on the street with our new design.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 03-05-2012, 12:58 PM
TWS
TWS's Avatar
Good talking with you just now Kevin.
Here is my new BMR sway bar next to the stocker it replaced. Makes the little stock piece look like a twig.
Finished the install on Saturday and took a test drive that night. No issues driving it on the street.
Quick Reply: BMR Launches New Product - Xtreme Anti-roll Bar (XSB001, XSB002)
