What size brake line 98 transam
You should have 3/16 line I believe but I am not sure on the fitting size. I do know that they use a ball flare and you need a special flare tool for that. Also they are not the easiest flares to make and a lot of people who have not done custom lines usually have leaking problems. Much easier to just buy new lines for back there. If you are going with the original metal lines then they wont cost to much.
