Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird CTS v Brake Install with Pics<br>Step by step instructions for do-it-yourself repairs.
F-Body with CTS-V Calipers 14" Rotors and 17" rims
#361
I used the stock banjo bolt from my 4th gen for the ctsv calipers, as for the brake lines you will need longer ones, somewhere within this thread is a link as per who has the correct length ones. If I remember its core-3 but im not 100% positive
#362
Coming back to this to help my braking balance. I've got a front C6 caliper conversion which required trimming off a spindle ear for the adapter bracket.
I need to switch back to stock spindles for the Gen1 4-pot calipers, correct? And I need different brake lines? What range of rotor diameters are compatible with the Gen1 calipers (c6=12.8, C6 Z51=13.38, C6 Z06=13.97, CTS1=13.98, etc.). What's the desired minimum gap between the wheel barrel and the caliper to prevent the caliper from touching the wheel when driven on a road course?
#363
Great thread ! I have brembos on my g8 and I'd really like to run a cheap 17" drag wheel.
Does anyone know if it's possible to fit a c5z wheel with just alittle grinding ?
#364
idk about a 17" but with a 1/2" or 5/8" spacer i run 18" CTS spare tire wheels on the front of my 99 with the brembos when im at the track. ive gotten the wheels free at the you pull it yards
#365
Just bought a 94 Formula completely stock with 42,000 miles. Just added 17" Speedlines and gathering parts for the brake swap.
The 2010 SS rotors will be here in a couple days and just started to mock-up the ls1 spindle with 0.8" spacing from the hub(z06 rotors measure 0.3", so if the Camaro is about the same or thicker a 15mm spacer should work).
Here is a vid of it spinning without lug nuts on. You can hear it scraping a little.
https://drive.google.com/open?id=1N4...Rmh3TeAWcTc8wM
Here are a couple pics of the points of interference. I will sand the caliper and probably take some off the wheel also.
I know this is an old thread but once I'm done I will post pics/info if people are interested.
Knute
Knute
