Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird CTS v Brake Install with Pics<br>Step by step instructions for do-it-yourself repairs.
F-Body with CTS-V Calipers 14" Rotors and 17" rims
Yes, I used two washers to bump the caliper over and center it over the rotor. As for the wheels you have it all depends on the backspacing weather it will clear the outside buldge of the caliper
Not at the moment, and I just pulled the factory subframe out and am swapping in a BMR so when its back together ill throw some pics up from under the car. I can take a pic of the rotating assembly all together on the spindle from the back side if you wish to see it that way.
Yes pictures would be great, and maybe u can measure the inside of your
ZR1 type wheels and we can measure our Fikse wheels to see if we could get those CTS-V calipers to fit
ok the rim backspacing spec is +56mm and with the 1/4" or 7mm spacer I used that would make +49mm backspacing, which left me with 6mm clearance between the spoke of the wheel and the buldge of the caliper's outer bucket. The clearance measured between the grinded area of the caliper and the inside of the rim was 1.5mm or .050"
CLICK ON IMAGES FOR LARGER IMAGE
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
No I didn't have to grind very much, if I knew how to post bigger pics I would, I click on that insert pic icon and that's what goes up, what do I do to make them larger?
#33
I have a couple sets of these calipers if anyone needs em quickly.
(yeh i know sketchy, random no post guy selling stuff... i spend most of my forum time on ls2gto.com. figured id throw it out there)
