About to buy SLP SFC's..Last min. HELP!
I'm thinking of ordering SLP's SFC's and read that they are 20lbs each? Is that amt. of weight bad for the overall performance? If so who has SFC's that are lighter than that? And finally, i was reading the install for them and it is talking about grinding down the a lip, this isnt bad for the car? I didnt really want to get into drilling out holes and what not. Let me know, thanks all!
I would suggest getting the SLP bolt-on's or Don Goetz bolt-on's, not sure which install you were reading but here's a SLP write up. http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
Al
Al
If you want bolt on's, I'd say go with SLP in this case. I have the jegster's, and during the install, Dark Age 53 and Smokin Joes pointed out the difference between mine and the SLP's, and the SLP's seemed a ton easier to install. And 20 lbs doesnt' sound too heavy, mine are definately way more than that!
Originally Posted by 99CamaroSS
Ok, SLP Bolt ons being ordered tomorrow, one last question, LMPerformance has them for 290 or suttin close to that yet LS1Speed.com has them for 250, am i gonna regret gettin them from the cheaper site or should i go for it? Thanks for all the help!
I installed the SLP bolt on SFC last week. I didn't grind down that lip at all. Aslo, only had to Drimmel one of the predrilled holes to make it match up with the crossbrace hole. Do that, I stripped one of my crossbrace holes during install cause it was slightly angled, so only 3 bolts holding the center rather than 4...not good.
The pass side took little while to install. First side I done and actually the first set of SFC's I ever put on. The drivers side went on twice as fast but we had to cut the plate (mod it a little) that goes around the fuel lines. You will notice a big diff. in the way the car rides.
Two suggestions though: Have a buddy help you out if possible and don't bolt everything down tight (with permatex red) till you get all the bolts started and snug.
I had no problems with the center brace though...............good luck.
Originally Posted by DARK AGE 53
Who is that?
Kenny brown Double Diamonds. They cost more but from an engineering perspective they are probably the best you can get and will tie the car together very well. Anything "bolt on" will not perform as well as "weld in"
Originally Posted by ynkssws6
I just ordered the SLP bolt ons, someone was telling me that they will eventually stretch out the holes, is that true?!
