Big cam? Car stops like garbage?
I drove a stock ss last week with the same pads/ rotors as me and it was much more responsive and stopped way better. I also have braided lines and ate fluid where as this car didn't. I do however have a decent sized cam in my 416. Anyone had this negatively effect their braking? Or do I have another issue?
Soft pedal? Its possible you may need the brakes bleed with the Tech-2 or any other scan tool that communicates and commands solenoids in the ABS system. Commanding the ABS Solenoids open and forcing high buildup pressure in the modulator out the solenoids will remove all air in the system. Sometimes air is trapped in the ABS Module and cant be bleed out with normal pedal push bleeeding.
Just another thought on your delema
Big cams will have a big impact on engine vacuum. Use a scan tool to monitor MAP kPa and I'm sure it's in the 65-70 range at idle. Also ceramic brake pads are softer than a semi-metallic pad and will cause a softer pedal.
Interested in the results. I have a 235/240 111 in my 346, and my sisters stock motor Formula (with same rotors and pads) stops way better. I've tried bleeding mine twice, the 2nd time after I made the ABS trigger - it still sucks
