Trying to diagnose rough ride
Old 11-12-2012, 08:14 PM
Beastmode89's Avatar
Default Trying to diagnose rough ride
I have been having issues with a rough ride in my DD 2002 T/A. I bought the car recently as a DD and it wasn't in the best condition. It had 94k miles, lowered on stock shocks and eibach pro kit. The rearend broke shortly after buying it. I took the opportunity to fix multiple things at once.
-rear rebuilt with ratech deluxe gear install kit. did not replace gears.
-replaced one of the axles (not sure what brand, mechanic ordered it)
-replaced shocks and springs with SLP eibach/bilstein kit
-replaced rotors and pads (cheap stuff from ws6store)
-installed adj panhard bar and LCA relo brackets that are set to the lowest hole (founders)
I just got the car back and decided to drive it to a conference this past week. At interstate speeds (75-85) I am getting a very constant bounce. Like the kind that rattles your teeth. Where do I need to start if I want to eliminate this problem?
Wheels are c5z replicas 17x9.5/18x10.5. Nexen 3000 275/40r17 up front and Nitto Invo 295/35r18 out back. Tires have about 7k miles on them. I think I'm running either 32 or 36psi all around.
Thanks
Old 11-12-2012, 08:28 PM
N20zuki's Avatar
Have you had the tires balanced yet? Thats the first place I would start.
Old 11-12-2012, 08:33 PM
Tires were balanced when they were installed by discount tire 7k miles ago. I also had the car aligned a few weeks ago when I got the shocks/springs installed. Would they need to be rebalanced after changing the ride height of the car?
Old 11-12-2012, 08:51 PM
02TransAm/Batmobile's Avatar
Is the SLP/Bilstein combo a brand new setup or did you buy it used? The bouncing could be attributed to poor rebounding from the shocks.
Old 11-12-2012, 09:11 PM
VinR1's Avatar
Sounds like a bent axle... Put the rear on jackstands, start the car, put it in gear, and look for any slight wobbling on either wheel
Old 11-12-2012, 09:59 PM
Shocks and springs were brand new from ws6store. Wouldn't the car be rough at all speeds if the axle was bent? It's smoother at 120 than it is at 75-85. It's also really smooth at low speeds. Just rough at interstate speeds. Highway speeds are fine
Old 11-12-2012, 10:32 PM
VinR1's Avatar
My bent axle vibrated progressively harder up to ~60mph then suddenly went away...
Old 11-12-2012, 10:45 PM
trans_am7935's Avatar
sounds like a wheel is out of balance. that is the sweet spot for slight out of balance. it a inner wheel weight was scratch and material was removed, that could to it. that happened to me when i took the wheel off to fast, it fell on the rotor and removed some of the weights material, had a vibration from 55-65 till i rebalanced them. it is a cheap fix, i would just get them rebalanced.
Old 11-13-2012, 06:52 PM
I'll drop by discount tire after work one day this week and see if a balance does anything. I swear this car has been nothing but a money pit since I bought it. I might just sell it and get a frc for my dd, or steal my old dd t/a back from my wife and get her a car
Old 11-14-2012, 01:29 PM
I hear ya. Either we spend money fixing it or we spend money modding it - it never ends!
Quick Reply: Trying to diagnose rough ride
