Strano 35mm Front Sway Bar - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 12-07-2012, 09:29 PM
Default Strano 35mm Front Sway Bar
Ordered a 35mm front sway bar from Sam Strano last Thursday, got here yesterday and I put it on today. Immediately when I opened the package I was impressed. This is a beefy bar, but surprisingly lighter than what I was expecting. Comes with the bushings, the bushing "clamps" (not sure what to call them?), and new endlinks. These endlinks are ****** beefy too. My old 32mm bar had Energy Suspension endlinks, which were a 13mm bolt and nut; the ones that Strano sends out have an 11/16" bolt and nut (which is between a 17mm and 18mm, to give a comparison).
I got the old bar off and the new one installed in about 45 minutes (I have access to a drive on lift). The difference was immediately noticeable. I took the car on a "spirited" drive on a curvy road and it handles beautifully. The front feels like it has a lot more grip and responds very well when you start turning the wheel.
I will admit that I did not get the 22mm rear bar that Sam suggest, but plan on buying it here soon. When taking some tighter turns you could tell that the car wasn't quite balanced with the 19mm rear bar I have right now.
Just felt the need to give Sam a shout out since I'm yet to get bad advice or a low quality product from him.
skimphish is offline
Old 12-07-2012, 09:57 PM
3rd gen V8 fbodies came with a 23mm rear bar that will fit your car - I found one in a scrap yard for $6 with bushings
...just to hold you over til you can swing the lighter Strano unit
VinR1 is offline
Old 12-07-2012, 10:36 PM
Is that all V8 3rd gens? The JY here sells sway bars for $15.
I don't have an autox event until February or March, so I'm not in a big rush to get one. lol
Old 12-08-2012, 09:01 AM
...the later years
just measure - 23mm is a little under an inch
VinR1 is offline
Old 12-10-2012, 01:08 PM
LS1TECH Sponsor
Sam Strano's Avatar
23mm was one bar that came on 3rd gens. So was 18, 19, and 24... The fact is solid 23 is IMHO too stiff (and about double the weight) and of course no new bushings and links either.
If you were to try the junkyard route find a solid 21mm instead, though the same issues exist.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Sam Strano is offline
Old 12-23-2012, 11:11 PM
I just saw this 2 weeks later. lol.
I'm planning on getting your 22mm here soon, work has consumed me since I got the 35mm and things are finally settling down.
The more I drive this car with this front bar the more I love it. Wish I would have skipped the 32mm and went straight to this 35...
Old 12-23-2012, 11:13 PM
bayer-z28's Avatar
I've got both his bars. Good pieces. I just need to get rid of that damn eibach/bilstein kit and get some good wheels and tires on the car so I can push it.
And you'll need to rear bar or the car is too loose. The matching bar in the rear didn't make mine want to over-steer as much.
bayer-z28 is offline
Old 12-24-2012, 02:13 PM
HioSSilver's Avatar
How much does this front bar weigh?
HioSSilver is online now
Old 12-24-2012, 04:35 PM
unioncarpenter84's Avatar
whats the price on the front bar with all the bushings
unioncarpenter84 is offline
Old 12-25-2012, 09:15 AM
I didn't weigh the bar before I installed it, so hopefully Sam answers that.
and the bar was like $210 shipped to my front door. Sam will advise you to just go ahead and get both because it saves like $20 in shipping, I just needed to buy in 2 steps. lol
Old 12-25-2012, 04:05 PM
I have both of Sam's bars and like them well worth the money.
Rodinator1234 is offline
Old 12-25-2012, 08:59 PM
do aa few millimeters on the sway bar make that much of a difference
Old 12-26-2012, 11:39 AM
LS1TECH Sponsor
Sam Strano's Avatar
A massive difference. Being a torsion bar, you take the diameter and multiply it to the 4th power. Not times 4, to the 4th power. And because of that, the bigger the bar is, the more difference every mm of diameter makes.
__________________
Old 12-26-2012, 11:47 AM
SparkyJJO's Avatar
So to put that in raw numbers...
32^4 = 1048576
35^4 = 1500625
That measly 3mm difference ends up being quite a lot.
I don't know all the physics and math behind torsion bars, but I just did that out of curiosity after reading Sam's post. Whoa.
SparkyJJO is offline
Old 12-26-2012, 11:59 AM
LS1TECH Sponsor
Sam Strano's Avatar
Amazing isn't it? Here's one for you: C6 Corvette fronts. A solid 35mm front bar is 12% softer than a 38mm hollow bar with 4mm wall tubing (I use a 6.25mm wall on the Camaro front bar just for reference to maximize the stiffness while minimizing weight).
__________________
Old 12-26-2012, 12:21 PM
damnit these threads keep popping up about sams bars....
if i hadn't just spend a boatload of money on christmas, I'd probably buy them for myself.
Oh well, good birthday present for my birthday next month
bill12690 is offline
Old 12-26-2012, 12:36 PM
HioSSilver's Avatar
What do your bars weigh Sam? each
Old 12-26-2012, 12:57 PM
SparkyJJO's Avatar
Mind = blown
This is why you do this stuff and not me
Old 12-26-2012, 02:41 PM
LS1TECH Sponsor
Sam Strano's Avatar
Front bar is about 17 or 18, rear is around 5. Hardware adds some, but all bars need it and the boxes too which are 56x21x3" each. Front bar ships at under 22 pounds with all that stuff, rear @ 10.
__________________
Old 12-26-2012, 03:28 PM
bluestreak98's Avatar
I was trying to decide if i want to buy a new ATI dampner or the Strano Hollow sway bars with my Christmas money. I think I'm gonna get the sway bars!
bluestreak98 is offline
Quick Reply: Strano 35mm Front Sway Bar
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
