WTF happened to my friends e-brake?!
He went to pull up on it and put it back down and this happened
(see attached pic)
I know it's a crappy picture but if you look at the front of it you will see the button popped out and there is a spring there ect.
how do we fix this??
thanks
-Steve
(see attached pic)
thanks
-Steve
It sounds like the plastic button on the end broke and the spring popped out. If that's the case you will need to get a new button from the dealer unless you can find a salvage yard close by with a f-body. If it didn't break, then the button came loose some how allowing the spring to pop out. You put it back together by sliding the whole cover off. There is a screw on the side down at the bottom that you will need to take out first.
