MS4 cam, now brakes wont hardly work...HELP!!!
So, I installed a MS4 cam in my 4th gen last fall now the brakes are so weak due to loss of engine vacuum, that i cant barely stop the car.
My question is what do you guys recommend doing to address this....Manual brake master?....vacuum reservoir?....electric vacuum pump?
Im open to any and all suggestions?
An ms4 will make it feel funny......try taking it up to like 4000 rpms and try to hit the brakes......they should feel mostly normal........if they don't look for a loose hose......I have a 236 238 112 Lsa and they only feel different when I try pumping them at a stop.....or just a tiny bit different when below 1800 rpms
i should have specified this is really only an issue at speeds above 90 mph... drag strip and when playing with porsches at high speeds, vacuum is good at idle the problem occurs at higher rpms
