Rear rotors with OEM size inner bore for parking brake
Hello people of LS1Tech,
My car is not a daily driver, and gets less than 3k miles on it per year. In 06/07 or so, I put brembo blanks on it, and lost most functionality of my parking brake as the inner bore of the rotor where the parking brake hat meets the rotor is larger than stock. I tried adjusting them to absolutely no avail. Now, it's time to change them, and I want to make sure I get a set of rotors that will allow me to use my parking brake again.
I figured I could just use OEM rotors, and am prepared to do so if I must, but am asking here first if anyone has any suggestions for rotors that have OEM sized inner bores. I plan on autocrossing the car, and doing occasional track days, so an upgraded rotor is ideal, although not necessary since it is the rear brakes.
Thanks,
Jake
Thanks,
Jake
Thanks for the offer, but I have no idea. I didn't realize the reason my parking brake became inoperative is because of the inner diameter of the rotor until I did some searching on this site and found people with similar problems. I need to find some OEM Delco rear rotors and measure those first. Or else I'll just order a set of the Delcos and be done with it. Just hoping someone knew off hand.
Thanks again, mate.
