Will BMR springs lower a V6 Camaro
Like the title says. Car is a 95 with the 3.4/4L60E. Its going to be swapped for a 6.0/4L80E once I'm done collecting parts. I'd imagine it will still lower it but not the advertised amount and probably be stiff but I can't imagine there being much weight difference between the iron 3.4 and the LS1.
There is a difference. Pretty sure the iron 3.8 is heavier than the 3.4, and the front of my car didn't drop quite as much with Stranos as it would have with the LS1, although the rear is about spot on (I knew this going in, though I'd still like the front to drop a little more personally). I think weight distribution plays a part too - the V6 engines center their weight further back due to being shorter.
