Manual Brakes (Stiff Pedal, no stopping power)
Installed the mwc manual brake kit on my 95' Trans Am, I got a good pedal, but just doesnt stop. Anyone have this issue or know the problem. Bench Bled the master, then bled the lines. Thanks
I was under the impression from mwc that you can install this without modifying anything. So stock calipers and rotors. No one said anything about drilling anything besides the pedal either.
I am running manual brakes on single piston calipers all the way around...
Can't remember are the LT1's dual piston front and single rear???
From the sounds of it I would say the master cylinder bore is to small, which would cause the issue you are speaking of....I am sure MWC is selling a 1.03 bore MC which should be right, but may have been mislabled....or such.
LS1TECH Sponsor
You lost the power assist but nothing else changed. You need much more powerful pads now to compensate for the loss of applied pressure to the calipers.
This is no different than someone taking off their power steering belt and wondering why the car is hard to turn all of a sudden.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
what do you recommend? I can push as hard as I can rolling like 3 mph and takes like a bit to stop it. I just did the manual conversion that's it. Yea did the manual rack too, see what you mean.
1.) Large cams don't create enough vacuum to properly run power brakes.
2.) Increased room under the hood
3.) Weight (although not much)
I've been running manual brakes for over a year. When I converted over, I also ditched the stock master for a Wilwood master that was 1/8 inch smaller in bore size than stock. I attached the brake rod to thw upper hole (2nd gens are pre-drilled for manual brakes). My rear brakes are LS1 f-body, and fronts are 6-piston Wilwoods. I had to do a lot of monkeying around and testing to get it perfect. The pedal feels hard, but the car stops on a dime. If you feel a hard pedal and can't stop well, it sounds to me like it could be any one of the following:
1. your master cylinder bore may be too large in diameter.
2. The angle of the push rod, compared to the pedal shaft, is far enough off from 90 degrees that you're actually losing mechanical leverage.
3. You kinked a brake line somewhere.
Anyway, its worth looking into.
Its the same Strange Master Cylinder everyone runs. I think most of the 4th gen manual brake kits have the same master cylinder. I still have stock lt1 single piston brakes. Would going to the ls1 front brakes help? Or be worth doing? I checked the lines, re bled the brakes. No leaks or anything.
LS1TECH Sponsor
We'd have to talk about options available (not sure if you changed to LS1 fronts or not), but there are definitely pads that will offer you a lot more bite, just a matter of what you are willing to live with to stop. Some might be dirty and noisy, but they'll work to stop you better. Or you can do back to power brakes with somewhat less aggressive pads since you'll have the mechanical advantage back.
__________________
After some research I see my master cylinder has a. 1.125 bore and according to strange that's recommended for 4 piston calipers. They make a 1.032 bore master cylinder thats recommended for single and dual piston calipers. Its what my kit came with. So switching to a smaller bore should help my situation along with good pads. Cheapest way to go would be a new master off a 89' caravan that's just about 1" bore and $30. That's if using stock lt1 brakes.
