Question on Rear Sway Bars, have you tried these?
Is anyone running a Suspension Techniques or a ADDCO rear sway bar? Any opinions on them? The ST is 1" dia. and the ADDCO is 7/8".
I am kind of debating between the 2 right now, the ST is $30 cheaper, but I am willing to spend the extra $ for a better item.
Moderator
Have not tried anything above stock. I believe you
really want to be looking at sway bars as a pair,
the match in rate between front and rear (on a
car that came set up pretty balanced) can affect
the cornering a lot. Harder rear swaybar is prone
to make the car oversteer (tail-happy) which it
doesn't particularly need, anyway. I know there
been posts about this, here, and you ought to
look into the combo rather than the piece-part I
reckon. Or I guess you could decide to get the
front after you find out for yourself, but you may
be better of in the end with a package price.
Still debating over which one though
The roll stiffness depends on what rate of front and rear springs as well as front bar that you already have. I debated on getting a front and rear bar together. I bought H&R springs and a ST 35mm front bar. The car is pretty neutral, it doesn't really push much at all, get on the gas in a hard corner and the rear gets loose, more rear bar would make my condition worse.
Briran
Briran
That's all I know.
Originally Posted by z28hokie
I've heard Addco makes BMR's swaybars for them...then BMR takes care of powdercoating.
