LG's LCAs + BMR relocation brackets
master of the "jack"stand
I put LG poly/rod LCAs on with BMR relocation brackets. I had to grind the spacers for the rod end down in order for them it fit into the housing of the relocation bracket.
Geez ... don't grind the spacers. Too much risk of getting the sides out of parallel.
Take a bar and open up the relocation brackets. Chances are very good that when you tightened up the other set of LCAs, the brackets squeezed in.
When you get the LG LCAs installed and tighten, they will squeeze to the spacer width.
I was concerned about getting them out of parallel, but I'm not sure what would happen if they were ground crooked??? What would be the consequence? Improper load in the relocation housing? Subject to loosening up? I was wondering if I was worrying too much...
Originally Posted by ChevyWeatherman
I made sure they are parallel (or very very close). Both the relocation brackets and the LCAs were brand new.
In my case the assembled LG LCA's (with dust boots, spacers, and rod end) were too wide to fit into my BMR bolt-in relocation brackets. I mic'ed everything and it turned out that the rod end assembly was exactly .200" too wide on both sides. I took the spacers to a local machine shop and had them remove .100" from the large end of each spacer. Any shop with a lathe should be able to do it accurately. Fits like a champ now. Definitely don't cut the spacers down with a grinder, hacksaw, etc. - not a good idea.
Well, if there is an issue w/the LG LCAs and BMR relocation brackets, what other bolt-in relocation brackets are avialable that will definitely work w/the LCAs? The LCA relocation brackets on LG's site say that they are weld-ins.
Well, I did it carefully, and haven't had any problems. I will keep my fingers crossed. If this could potentially be a serious problem, I hope someone will let me know, if so, I can call LG and order some new spacers, then have them professionally machined.
Just for the record the machine shop I went to did the work in about 5 minutes for $10 in cash walking in off the street. If you don't have a set of calipers, you can pick up a cheap set of digital ones from Harbor Freight for ~$25 that'll work pretty well for this kind of measurement.
Shoot me a PM if you have any questions.
Larry,
I talked to Louis about this combo a couple years ago and (IIRC) he basically said that they build their stuff on one end of the tolerance range while BMR apparently builds on the other end in this case. Any time you mix/match different aftermarket parts you open yourself up for this kind of thing. Nothing new nor is it unique to this application.
Bottom line- if you want to run BMR relocation brackets with your G2 LCA's just plan on spending a few extra bucks having the spacers modified. Its really not a big deal.
Larry,
Thanks.
Originally Posted by 99BackNBlackZ28
Thanks for the info. Two more questions to throw out there though. 1) Is there any other company that makes in bolt-in relocation brackets that would work & 2) what type of shop would be able to modify the spacers? ???
Thanks.
Thanks.
Any competent machine shop with a lathe can modify the spacers for you. Just remember that the material must be removed from the large end of the spacer.
