Cannot get UMI solid motor mounts to line up
Been trying to get these things in for 2 saturdays now. First i got the passenger side all bolted up. When i went to put the bolt through the driver side it is a half hole off. I could almost get it pryed over but no luck. Next i undid the passenger side and bolted up the drivers side first, now i have he same issue on the passenger side. My next plan was to pull the intake and lift the motor up from the top, right now ive been working with a jack from the bottom.
Any other tips? Am i over looking something? Ive never had something that should be so simple give me such a fit
Hello,
I will be glad to help.
How old are the mounts? I ask because we had a few sets go out with "UP" engraved on the wrong side. The mount is perfect but when engraving they got put in the machine wrong. If you can PM me e-mail address I will send instructions to show which way is up.
Second, is this in the factory k-member or aftermarket?
My buddy had the same issue mounting his engine. You can try mounting everything in the car while the bolts are loose so there is some wiggle room. once in and where you want it,then torque them down.
Loosen everything related to it, including where they bolt to the motor and or k member. Solid and even polys can be such a pain in the ***. The more stuff that is tightened, the less chance you have of them lining up.
Hello,
