Any tips to get the ET 275 Pros to work with my suspension.
I've been running a 28x10.5 ET drag. Just curious if you guys think I'd be wasting my time trying the newer ET 275 radials? I have single adjustable QA1s all the way around, UMI T/A, single adjustable LCAs, spohn drag sway bar. Car makes 875 right now. Have 3:73 gears and a th400. Think I can get them to work leaving @ 5k with a procharger?
LS1Tech Premium Sponsor
If you are switching from a bias ply to a radial, you will need to change up your shock settings a little and may need to take some anti-squat out of the rear. The radials will hit alot harder and tend to bring the front end up faster than a bias ply. Try tightening up the front shocks so it doesn't come up as fast, and loosening the compression on the rear shocks to help the suspension absorb the shock that the tire used to
When you purchase shocks get them from a reputable shop that works with the fastest stock suspension radial f-bodies in the country... MWC. Take what you hear here with a grain of salt... info may not be correct. Trust the people with proven performance!
MWC has the guaranteed lowest prices on any suspension component and the best tech help available.
Just curious also, what do you mainly do with the car? Is it strictly a drag car, or do you street drive it still as well? What some people may suggest will work for an all out drag car, but for most people who enjoy a double duty car, there are a lot of variables. Before throwing more parts at the car, try dialing in what you have. What may be the best for a dedicated track car, may not be a good option for the street. You have to weigh out how you use the car
