Can a camaro be built to out handle a c6
Is your dads C6 stock?
By what measure are you assessing handling? Are you two competing in Autocross or some other timed track environment? Or just comparing "seat of the pants" feel of street handling?
are you a better driver than your dad? have you considered doing a race school or something like that? How your car handles is directly related to your vision and how you use it..recepticals of info so to speak...a school may help you "see" that. lots of books out there on how to become a better driver. typically, cars can do more than their drivers so learning how to drive your car (to its handling limit) may help you realize how good a driver you really are...food for thought.
if you're set on modifying the camaro, be prepared to open your wallet...the location of the weight on the camaro makes it unbalanced out of the box. Leveling the playing field would mean getting you to an equal power to weight ratio...the vette has approx. 300lbs on the camaro...so lose weight and/or add power proportionately. bone stock the camaro has difficulty putting the power down, unlike the vette. so suspension and a differential will go a long way in this department. because of the weight's location on the camaro, your suspension will have to be that much better than the vettes...particularly if the camaro remains at the same weight.
my 2 cents.
Technically yes, but you'd be better off buying a C6 at that point. You'd have to change a lot, possibly even make the car no longer have a solid rear axle.
LS1Tech Premium Sponsor
Easily. We have many customers who are capable of it. It just takes careful part selection to make it happen. You can't just throw a bunch of off the shelf parts at it and hope it works. It is best to plan out your suspension and select components that compliment each other to work well. If you need help with parts suggestions give us a call and we can get you pointed in the right direction
Unless your fundamentally re-engineering the car from the ground up... I will concur with "no".
Live axle will never keep the tires pinned on uneven road surfaces as well as an IRS. Watts link be damned, unsprung weight is the enemy.
For that matter, the cast Iron knuckles used in the F-body aren't even as remotely light as the aluminum units used in the C4, let alone the C6.
Agreed, it would be great to understand a little more of the context here.
Without considering cost or value, the C6 is clearly the better handling car. You could spend money upgrading an F-body to run with them (as many of us on here and FRRAX prefer to do), however if you're trying to lay down a better lap time or faster time in A/X and neither of you have track experience, the single best advantage you could get would be seat time and experience.
To put it in context, check out this thread -- good for a laugh. https://ls1tech.com/forums/road-raci...arn-track.html
I'm going to disagree with a lot of the opinions in here, and leave you with this. This 4th gen uses our suspension and would make quick work of a stock c6, as it did with the many highly modified Cobras and the 5th gen chase car. All of which are also IRS, BTW
I feel like you're just waiting for one misinformed person to say "put on lowering springs and it'll be better" so that you could brag saying it would be easily possible, and don't like the answers given. It's possible, but isn't cheap and imo it would be better to just save and buy the newer car that would in theory also be more reliable, keep it's value better, etc.
STi Killer - Sebring - Track Guys - YouTube
A: A prepped track and a back road west of Bum-hump tx are two different beast. Im not a race car driver in any way, but that much is obvious.
B: Ill have to partially recant some of my my prior statement... *Ahem* A live axle camaro can be significantly upgraded to compete with a stock C6 in a track environment.
The video (one of my favorite articles surrounding a "bolt-on" track build BTW) shows the high potential of a modded 4th gen, but in all fairness, your driver would have to race in a stock C6 to give ground to the argument.
Key word is "country road". A non-race prepped, country road is full of lumpy transitions, breaks, and bumps that make wheels bounce upward.
If a wheel is bounced upward, its NOT pinned to the ground. With all other theory aside, the biggest factor in handling is simply keeping the tires pinned to the pavement. The best way to combat this inertia has always been to use components with lighter weight.
More un-sprung weight will make a bouncing tire hang in the air longer because there is more force acting against the springs. Less un-sprung weight will be easier for the springs to manage; and thus pin the wheel to the ground faster. The art of suspension is about managing inertia.
The solid axle of an F-body has 2-4 times the amount of unsprung weight, and thus that much more potential inertia. The cast aluminum upper and lower control arms of a C6 vette are MUCH lighter than the steel axle tubes, steel diff, and cast-iron diff housing of an F-body.
Unless someone makes an axle housing out of carbonfiber or similar lightweight material, there is no way to make the unsprung weight of a live axle less than the weight of an IRS LCA, UCA and aluminum knuckle assembly.
There is an odd catch 22 though... If it were possible to make a live axle housing as lightweight as the unsprung components of a C5-C6, then I believe the live axle would out perform the IRS simply due to the fact that a live axle does a better job of keeping its wheels square with the pavement.
An IRS has a changing tire patch in relation to its angle of articulation.
Hope I answered some questions.
