Anyone running a Three link on there 4th gen
I saw a road racecar today where they deleted the TQ arm and ran a three link like a circle track car. They made a bracket that bolted to the rear end and made a mount on the body. They used about a 8" piece of tubbing like a lower control arm would be made out of with a heim joint on either end. Is any one else running this? He said he liked it a lot better then the TQ arm what do yall think?
It's a great idea for a track car, changes the instant center under braking helping control brake hop. The downside is its a track only setup, as it needs to be built into a cage like the car you saw as the floor of an f-body leaves no good mounting points.
Another solution that accomplishes the same thing is Unbalanced Engineering's de-coupled torque arm. Google them (not a sponsor). It's a short torque arm that decouples under braking, giving you the best of both worlds. 100% bolt in. Be aware it's very pricey and will be discontinued at the end of the year. If its something you are interested in jump on the train now.
I agree. I had an oval track car, back in the 80s, and it had a 3 link deal. The upper link bolted to a pair of "downbars" on the cage. I highly doubt that the floor pan of an F-bod would have the strength for an upper link mount. Secondly, if you kept the OE floor configuration, the link would wind up being way too short.
