BMR Suspension newly released tunnel mounted torque arms!
LS1Tech Premium Sponsor
That would be this little guy; our new bolt-in Watts Link system for the 4th gen.
https://ls1tech.com/forums/suspensio...nk-inside.html
First, I would like to identify where your clunking is coming from. With everything installed correctly and tight, there should be no noises from either system. This new style torque arm will transmit less NVH into the cabin of the car so road noise will be less noticeable than a track pack. But for a high-horsepower, drag race oriented setup I would still recommend a track-pak.
No, I have several customers running this arm with a QP 9". To get optimal clearance, I do recommend some trimming of the bracket of both the torque arm and the QP mount. This tucks the arm in tighter and away from the tunnel. I have pictures of how this is done if needed I can send you
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
NVH with this kit is very comparable to that of an aftermarket full length arm and relocation crossmember. It does not have the typical issues associated with a tunnel mounted torque arm
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I believe it will. Here are some pics of our setup with a typical long rube header/y pipe combo to give you an idea what the relation will be to compare to your setup
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
