Anyone have IRS alignment drag specs?
LS1Tech Premium Sponsor
What kind of vehicle are you working with? I know with the 2010+ Camaros and G8 that we deal with we run the rear camber right at 0 to offer the largest tire contact patch possible. You will also want to run a little toe in on the rear of car, we like to see somewhere in the .20-.25 range. If you are using skinnies on the front of the car run the front camber as close to 0 as you can but if you are running a normal street tire on the front stick to the factory camber specs. Keep the front toe right around 0 also.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
