Multimatic DSSV dampers on 4th Gens?
I am curious, is anyone running Multimatic’s Dynamic Suspensions Spool Valve damper system on a 4th Gen, like they offer on the 5th Gen Camaro Z/28?
http://www.multimatic.com/motorsport...s-motorsports/
Yeah, those might actually surpass the coin needed for the already stupidly priced; Penske/Moton/Ohlins/Rieger/etc. multi-adjustable, reservoir dampers!!
Wasn't that pricey. The kit is under 4k if you can get the shocks alone should be a lot cheaper. Getting it set up in a 4th gen might be $$$ however.
http://www.phastekperformance.com/20...rts-s/1214.htm
Yes, just two of the reservoir shocks I've mentioned above could cost more than those DSSVs, but those are built with (and FOR) a fifth gen Z28's; total weight, weight distribution, instant center, center of gravity, roll center, IRS, etc. etc. in mind.
They may be worse than a set of Konis/Stranos on a solid axle 4th gen as far as handling goes.
