Koni and BMR combo couldn't be happier
Ride was getting pretty bad so I pulled the trigger on some Koni str.t shocks and struts along with some BMR drop springs. This made a night and day difference in the feel of the car and I couldn't be happier. I also achieved the stance I wanted, it doesn't look like a monster truck anymore. Before and after pics attached.
I would say so, I haven't actually measured ground to fender, and the 315s might kick up the back just a hair. I like a little rake also but I'm extremely happy with the stance I achieved. You could always go back later and heater hose the spring to kick the back up a little more as well.
LS1Tech Premium Sponsor
Looks good with all the new parts installed. Man did your car sit super high before you installed our BMR lowering springs!
Our springs are gonna offer a slight rake just like the factory ones do. The nice thing is that you can do the heater hose mod on the rear of the car and get rid of the rake if you don't care for it.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Any issues with the install?
Did you end up replacing or upgrading anything else? Adjustable Panhard bar? Adjustable torque arm or relocation bracket? LCA relocation brackets?
I have an adjustable PHB and Koni yellow's ordered and already have the BMR lowering springs, will be doing my install in a month or so.
How's the ride quality?
I too recently installed the BMR's with the Bilstein HD's... I actually replaced the Eibach Pro Kit, which btw the car rode, drove horribly. As others have mentioned the BMR's were night and day... Car is rock solid, not creaks,squeaks,bottoming out. For the record, I am running BMR front/rear control arms (non adj), SFC's,Adj PHR, new, shaved bump stops.
Originally Posted by bad_408_vert
Nice! Will be doing similar set up on convertible.
Good to see what it may look like for me.
Any issues with lowering and your 315s?
Originally Posted by Ls1N20
Looks like you're missing a bolt on one of your lower strut mounts...
Thanks
