27 inch tire enough to need adjustable LCAs?
So my Z28 will never see the track but I bought some 305/45/18 Nitto 555Rs for my Z06 replicas and just measured them at right at 27 inches high. I've been reading that adjustable LCAs can be handy when fitting an extra tall tire- are these tall enough where I should consider an adjustable? If not, I'd be perfectly happy to save the money on non adjustables.
This is my car with a 27" tall 315 on the rear with a 16" Corvette offset. I needed 3/8" spacers.
Seems like the more I research the more questions I have. What are the benefits of LCA relocation brackets if my car is NOT lowered?
Also thanks for the info Rampant. I'm hoping I can get away with just banging the inner wheel well a little since I'm only trying to get away with 305s.
LS1Tech Premium Sponsor
on a 27" tire you will be good with non-adjustable arms. if you are still stock height, running relocation brackets will still benefit you. You can just run them in the upper hole. This will give you a more aggressive anti-squat angle than stock without altering wheelbase. Plus, if you lower it later, you will be able to drop the arms to the lower hole to maintain geometry
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
No 2 cars are the same per say when it comes to tire sizes and whether you need "ADJ" control arms.
What I can tell you is that if you ever need adj. control arms because of a fitment issue you'll wish you would have spent a little extra money when you bought the non adj style.
It could come down to the old saying...."do it right the first time"
Craig
