Relocating rear lca inward, Fbody
High all, I got new wheels and my tires are rubbing the offset lca slightly. Can I move the front of the control arm to the inside of the mounts without strength problems? I have bmr subframe connectors that ad quite a bit of steel over the factory box. Do you think this would be ok in hard 60fting car, 1.2s.
Here's a pic, this is with the old rim as now the tires are touching the lca.
https://i.imgur.com/1QWpd6N.jpg
LS1Tech Premium Sponsor
From your picture, it looks like you could probably get away with sectioning the LCA mount and subframe perch and eliminate the long spacer. If you go tot the inside of the mount, it will put your arms at an angle, and put the mounting bolt in single shear which would be a serious strength issue. Unless you add material to the inside to re-box it. I would honestly take a cut off wheel and section that box inwards 1"-1 1/2" to clear and re-weld it and run a shorter bolt to eliminate the spacer
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I was thinking of moving it to the other side of the mount on the thinner bushing side and making a solid spacer across the factory location and using a longer 1/2" bolt.
It will misalign the LCA compared to the rearend brackets, I do not suggest to do what you are thinking about.
I have moved the LCAs to the inboard side of the brackets on some of the fastest stock suspension f-body cars in the country(the inboard bracket now becomes the outboard), but you have to relocate the shocks to do this.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
The problem is now the tire is touching the lca since I've tucked the rims in, even with offset bushings, it's not the bracket it's the lca itself. So it's not good for the lca to be angled in slightly from front to back if I were to to move the front inward and box it into the other part of the frame rail on the left? Thanks for your guys insight!
