Best bang for buck brake upgrade
Ha! Drive an LT1 and you'll appreciate those brakes you have on now.
Most cost effective way is to try a good pad and rotor combo on your current setup and bleed your brakes with new fluid as well. If that doesn't satisfy you, a brake upgrade kit is your next best bet however it gets more pricey. I believe the LS1 brakes are perfectly capable for a F-Body anyways, I've seen an F-Body with a C5 conversion brake kit up front lock up the front tires on a course multiple times, and that's something you don't exactly want to do. He was running an alright sticky tire too
A good blank rotor with upgraded pads on front will do the trick. Something basic like a Hawks HPS or 5.0 up front will be an upgrade to the stock pads and will suffice for your purposes.
If you have more tolerance for dust/noise on the street, the Hawk DTC-30 is a track pad with decent street manners (doesn't eat up rotors like most track pads). Held up to plenty of repeated stops from 145+ on the back straights at Road Atlanta.
http://www.g-locbrakes.com/about-us/
