Strano springs, sway bars, and Koni sports installed :)
This past weekend I installed:
Strano springs, Sway bars, Koni shocks. I also replaced the ball joints, upper shock mount, and all 4 springs sets. I didn't have enough time to do the bushings though. I don't think I am going to do that myself... Ball joints were a
I have the shock set to 3 sweeps from full soft front and 1/2 turn from full soft in the rear.
I previously had the bilstein eibach pro kit and never really liked it. Was always a really harsh ride. With the new Strano/Koni setup it rides way better. It feels like I actually have shock absorbers now I really like that I can adjust them now. It feels much better around corners too. Much smoother and more responsive. Brakes smoother too... Wasn't expecting that.
The one thing that seems weird to me is the front driver is a 1/4 inch lower than the other side of the car. The rear is perfectly level. I measured and compared the springs before installing and the fronts were the same height. I don't remember if it was likely that before. Is there a better place to measure? I have removed the driver fender before. Should I be worried about that?
All the Goodies
All the Goodies
Glad to hear about how happy you are from upgrading bilstein/eibach to strano and koni I have the bilstein/eibach setup right now and have been wanting to switch soon myself. I know the feeling with the ball joints....
I can't imagine the fender being lower without not fitting with the rest of the car, does it look lower if you look at the car from the front? maybe measure ground clearance from either side?
I installed my koni/strano's a few weeks ago
Mine measure lower on passenger side than driver side (from fenders to ground):
LF 26.75
LR 27
RF 26.5
RR 26.75
No worries to be had about different ride heights
LF 26.75
LR 27
RF 26.5
RR 26.75
Ah ok cool thanks. Just wanted to make sure I didn't jack something up lol. I installed the rear sway bar on upside down the first time... Working on cars while tired is a bad idea.
LS1TECH Sponsor
Hey Matt, thank you for a really nice concise write up (with some good pics too). I really like it when folks can compare and contrast setups, especially a common easy button one like you had before.
I think the car looks great too. I'm getting a hankering for another of my own and a WS6 is leading the way.
Keep me posted on your thoughts, maybe as you play with shocks and things. And thank you for taking the time to review!
Sam
Sam
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
So I got an alignment today. Nothing special just a standard alignment. I was told my Rear axle was "twisted" and that it could affect my steering slightly. Front alignment is good.
I can tell that the rear end is off center but I can't tell if it is "twisted". Any idea what I need to do to fix it? How much of an issue is it really?
LS1TECH Sponsor
I'm sure it's got some thrust angle (very common). You can fix that with adjustable LCA's. Basically the axle is turned a touch in the car. The RR may have a touch of toe out, the LR a touch of toe in, that is thrust angle.
As for the left to right, that's the PHB, but an alignment machine can't measure it and as you drive that is always changing due to the way a PHB (ANY PHB) attaches to a fixed point above the ground, the axle.... but the other end moves up and down, the body. That creates an arc that the body follows. That is what a Watts link gets rid of.
__________________
Ah that makes sense. Do I need to worry about anything getting damaged besides maybe some odd tire wear for the short term? I assume it's been like this for quite some time.
Meaning I could drive it daily for a few weeks or months until my budget recovers a bit lol. I was planning to do a adjustable pan hard bar and LCA's at some point this year.
I want to get it on a track at least a few times this year. Although it seems it's quite pricey to do so.
LS1TECH Sponsor
Not abnormal. Could be within spec. I can't know for sure, but have no reason to assume it's not within spec.
__________________
All the Goodies
All the Goodies
When you do get your adjustable LCA's and panhard, remember to center everything up while the suspension is loaded. Took me a while to figure this out after everything was squared up on the lift but crooked on the ground
I drove my car for almost a month with the stock panhard after my Koni/Strano install. Tracks sideways and looks funny but it's drivable, just don't go crazy with it
Here's my thread, You'll see where the washer goes, there's a picture of it with me pointing to it
https://ls1tech.com/forums/suspensio...ni-strano.html
Lol I feel like I'm walking you through the whole process, but the install is decently fresh in my mind so I'm glad to help out all I can. The washer goes right below the shock mount.
