5th Gen SS Spindles on 4th Gen F-Body for Brembo Break Upgrade?
I was mainly wondering if this were possible (or cost effective) as I know to do the Brembo brake upgrade, you have to enlargen the bolt holes on the spindles. While thats not too daunting of a task, it just leaves me very concerned about the integrity of the spindle itself as its carrying some of the most important components of the car itself.
Is it possible to just use a 5th Gen Camaro Spindle on a 4th Gen F-Body?
The front suspension of the 5th gen is totally different. It is a multi-link setup with a strut that the spindle bolts to. Not a short-long arm setup with a coilover shock connected to the lower arm directly like the 4th gen has.
In short - No.
In short - No.
LS1Tech Premium Sponsor
^ This. If you are looking to do a good brake upgrade using readily available factory parts, do the CTS-V calipers and Z06 rotors. There is a good write up on this forum of how to do this. Basically a bolt over swap
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Douchebag On The Tree
Correct, the hat thickness is the same between the Z06 and F body rotors so stud length and fitment won't change. The only concerns then will be wheel diameter and pad height because the new calipers being larger may have interference issues with the back of the spokes of the wheel
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
