F-body rear bump stops on the cheap
Bump stops on my 00 SS have been in need of replacement but the $70+ dollar to replace them had me putting it off. I came across info about using jeep bump stops and ordered them. Here are photos of the a comparison between the OEM stops complete with a few photos of what it takes to make it all happen using the OEM spacers
Well worn out bump stop on passenger side
Comparison between driver side(intact) and the Jeep bump stop
Here is a photo of the spacer clamped in a vise after I used a sawzall to cut off the step(done is about 45 seconds flat).
Installed back on car. As good or better than OEM. Energy Suspension 9.9137G are the parts I used. Red ones are available too for you flashy guys.
to keep your axle from slamming into the bottom of your car when you hit either a bump or a pothole. That way your tires dont hit the wheel wells, your shocks don't over compress, and your springs don't bottom out. If you are on any kind of lowering spring they are pretty much a necessity, especially on crappy roads. I'd say the same for stock springs too.
I should have researched a bit more to realize there were some rubber ones in this price range. The ones i've seen were like $80-$90.... which I thought was insane for bump stops. These poly ones from Energy are reasonably soft but may not be near as soft as the rubber ones. Now I'm curious.
I installed new rubber stops from Strano and left the spacer out, just need to trim the stop on one side to clear the lip.
https://ls1tech.com/forums/suspensio...ump-stops.html
