Removing stock torque arm
Ive done some searching and havent had much luck, gonna install a mwc torque arm with relo crossmember. My question is: what is the safest way to get the stock one off? Rear end loaded/unloaded? Unhook the front or back first? Never messed with a torque arm before so just lookin for some insight. Thanks
Rust is the killler where I'm from. If your car is put on the road before the end of may, you're gonna have it . Still for an 18 year old car , this is actually pretty good around here
Only if they were decarbons. Then it would've been +5 for all the red shiny bits and -10 for the decarbons, but they look like STR.t shocks so +2 for a grand total of +7 coolness points
LS1Tech Premium Sponsor
Good choice in parts
As for the original question, I agree with some of the above suggestions. Put the car on stands and the rear on a jack so it can be unloaded, but not totally free hanging. Take the rear bolts loose first and you can slide the arm out of the front mount. Then remove the mount from the tailshaft of the trans. Seems to be the easiest way I've found to do it. Either way you approach it, don't do it with the rear end loaded
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Northeast rust is brutal. I have a low mile car that has spent most of it's life as a fair weather cruiser. Paint and interior are immaculate. First time I got it on a lift was very disappointing. Everything that can rust has rust on it. Especially the rear, yikes. And anything aluminum under the hood is oxidized.
Looks like our torque arm, sway bar and k member though.
Still, better than seeing chinese knock-offs under the car
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
