UMI Releases New Product: Panhard Bar Lowering/Leveling Kit for the 1982-2002 F-Body
#42
LS1TECH Sponsor
I don't think that is the example you want to use. Who welded that? Popcorn Bob?
it's not indicative of how real, not boogered up exhausts fit.
__________________
The following 2 users liked this post by Sam Strano:
RedWS6 00 (08-07-2024), wannafbody (08-01-2024)
#43
Couple of questions, I will be purchasing the upgrade kit as I already have the phb relocation to clear my over the axle true duals and my car is lowered on Voghtland sprins with Strano Bilsteins and I have an S60 also. Where is the best setting when drag racing and what's the best for daily street driving thanks?
#44
LS1TECH Sponsor
And the concern about moving the right side of the brace down means you have to move the right side of the PHB down, and unless you have the full kit that also moves the left side down so you can level the PHB out again, you are simply causing more and more asymmetry in the system. And the whole time you are lowering the roll center too. You might want it low but if you don't, (and mine isn't that low) you get stuck.
__________________
#45
It is a an Unbalanced Engineering kit that lowers both sides and is perfectly parallel to the ground on my car. Sure its not adjustable but I have dialed in the springs and sway to my liking and as poor of a driver as I am, I have passed or kept up with my fair share or "fast" cars on the track. The upper brace is something I made out of a straight piece of DOM that I could have mounted lower to give even more clearance than the previous 2.5" dual OTA or the current 3.5" single pipe, which was Jim's question, about straight brace that can still fit big exhaust.
Maybe I should make a few and sell them since nobody else has, and I'll call them ugly sticks in honor of the booger welds! But Jim and I are apparently the only ones that want one anyway so if you want Jim, I got you
#46
If you concern is street driving and drag racing this would be best. I don't see much height adjustment being needed for that type of use.
I hope that helps,
#47
I know this thread is ancient now and this is a shot in the dark but... I'm moving along with removing the existing hardware to install UMI's 2062 PHB Relocation / leveling kit. I'm wondering what others have done about the exhaust heat shield that uses the factory PHB brace as a mount point in two places? I'd rather not remove it unless it's absolutely necessary.
#48
Can't remember now, but would it stay in position without those 2 small screws?
