Help! routing of brake lines for Hust lineLock
Old 01-16-2017, 12:01 PM
stroked383HSR's Avatar
Default Help! routing of brake lines for Hust lineLock
Hurst Line lock install
which line or lines do i remove and where do i connect on the solenoid?
i know i remove the rear line off the master (Which is for front brakes)
and said line off the distribution block.
thats where i get lost.
there are a R/L front brake line of the block....do i remove both?
im so lost/dumb when it comes to stuff like this.
the instructions dont have a diagram
Old 01-28-2017, 07:09 PM
anyone?
Old 03-07-2017, 06:28 AM
klinznilk's Avatar
You only need to remove the ONE line off the block. I can try and get picture of mine in the morning.
The one off the master cylinder just use a line wrench and remove. You will use the one line from kit to go from master to the solenoid.
Then the other shorter line will go from the solenoid to the abs block (the thing in your picture above that has the line removed.
Old 03-07-2017, 12:19 PM
picture would be great!
I know its the 1 line i have removed off the block and the rear line off the master
Which in?out ports on the solenoid do they connect?
master goes ??? on the solenoid?
abs block goes ??? on the solenoid?
thanks for the help!
I didnt get the line kit with mine....just the solenoid kit
so if you have part #'s or fitting types ...i need that too
Old 03-16-2017, 04:40 PM
klinznilk's Avatar
Mines not a hurst but should be similar (SJM?? i think mine is).
Also mine is front mount (more hidden) whereas yours appears to be top mount.
Hope this helps
Quick Reply: Help! routing of brake lines for Hust lineLock
