Question about Lubricating Poly Bushings during install in Control Arms
I'm in the process of installing poly bushings in my upper control arms. I went online to check how to properly lubricate the bushings and found some contradictory how-to articles. My question is...Should the outside of the bushing be dry when the bushing is pressed in? I've found articles stating the outside of the bushing should remain dry and only the inside diameter along with the sleeve that the bolt goes through should be lubricated.
Other articles and videos state that every surface of the bushing that makes contact with metal should be lubricated including the outside. What do you guys think? If someone with some real experience or knowledge could chime in, I'd greatly appreciate it. Thanks!
LS1Tech Premium Sponsor
you only need to lubricate the center of the bushing where it rides on the sleeve. Make sure to use a fully synthetic chassis grease on Poly. A petroleum based grease with dry out and break down the poly
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
When poly bushings are being pressed in to factory suspension components they should be dry when they are pressed in to the control arm - *part of bushing being squeezed into suspension component is dry. Then when you are reattaching the control arm to the chassis, the outer sides of the bushing should be lubricated. Are these preassembled Poly bushings or are you pressing them in to your factory control arms?
I'm going to have to disagree with Energy on their recommendation here. We always install bushings into our components dry and with a tight fit to the outside. Our bushings are fluted on the inside around the sleeve to retain grease and keep a smooth surface. Bushings should not rotate inside the outer sleeve they are installed into. All movement should be the rotation on the inner sleeve. When the bushing rotates inside the outer sleeve, it will wear the bushing and create tolerance and slop on the bushing. The inner sleeves are zinc coated to provide a smooth bearing surface for the bushing to rotate on.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Thanks for the reply. Unfortunately, I'm more confused after watching the video linked below when comparing it to your response. What looks like an Energy Suspension representative is stating to lubricate every surface area that contacts metal including the outside of the bushing where it makes contact with the outer sleeve. Start watching video at 1:50 to save time...
https://youtu.be/fpEZUbHVhUs
Thank you for your response. I had the same thoughts and felt that it made more sense to install them dry. However, it was very difficult to install them dry so I lubed them as stated by Energy Suspension. Now, the one bushing keeps wanting to slide out of the sleeve slightly and is not flush with the lip. I've attached a couple pictures. I was thinking about removing them, cleaning off the lubricant, and using some sort of non-petroleum based adhesive to keep them in place. Has anyone ever considered using adhesive instead of running them dry?
You're getting some movement of the bushing because you haven't squeezed the frame ears with the retaining bolt, at this point. FWIW, I may not be an "expert" with poly bushings, but have used them, beginning in the late 1970s. I've always lubed ALL of the surfaces, using either Energy Suspension's grease, or a similar, Teflon impregnated lube called 'Super Lube'................
I did decide to grease all of the surfaces. After thinking it over, I didn't want the bushing pressed into an aluminum sleeve dry. After listening to others advice, I figure it would wear out the sleeve faster if it was dry since there is still some movement on the outside of the bushing even though the main pivot point is on the inside sleeve where the bolt goes through.
