Are ATS 4 piston Brembros as strong as the GEN CTS-V/GEN5 Camaro Brembros
IDK. It likely has to do with how your hub mounts the calipers. From my understanding the 4 piston Brembos that the ATS/C7/GEN6 Camaro use have the same calipers other than maybe the paint. I believe the Camaro rotors on the 4 piston Brembo cars measure 13.6".
I've thought about this on my 19 SS 1LE when I have to replace the rotors. SS 1LE and ZL1 brakes are pretty much the same other than the ZL1 uses 15.1" rotors up front where the SS 1LE uses 14.7" rotors. IDK if it would be a direct swap to ZL1 rotors though. Really it probably wouldn't even be worth the added weight of a larger rotor on this car as it already stops on a dime.
