Need help with rear brake upgrade
Old 04-08-2017, 06:59 PM
s10pro's Avatar
Default Need help with rear brake upgrade
I have a 68 camaro with moser 9 inch with ls1 axle flanges any one ever upgrade there stick f body ls1 brakes ? If so with what thanks I wanted to do like a13 rear rotor setup .thanks for your help
Old 04-10-2017, 10:45 PM
Douchebag On The Tree
justin455's Avatar
No one with 4th gens really ever upgrades their rear brakes because it's dangerous on these cars. The bias is too rear heavy so upgrading the rears can cause them to hit ABS or lock up before the fronts causing erratic behavior under braking. That's why you're not getting any feedback or ideas.
Old 04-11-2017, 08:27 AM
TTur1996's Avatar
Since you said you had a 68 camaro. I would have to assume you have some sort of manual brakes with no ABS. Wilwood makes some for the street. I would suggest their master cylinder as well. The size of your rotor really depends on how big in diameter your wheels are, to be able to include the caliper outside of the rotor.
Quick Reply: Need help with rear brake upgrade
