Which springs if i remove Stranos?
I changed my shocks and springs a last winter to Strano lowering springs and Koni STR.T shocks. Ever since I changed them I have had to be careful because my cut out drags on everything and I just don't like the car being so low. I am thinking about changing out the lowering springs but don't know what kind to go back with. I have the factory springs I took off I thought about putting back but wasn't sure if there was a better alternative. The car is mostly street driven more of a weekend cruiser with the occasional trip down the drag strip. I am going to add adjustable LCAs, relocation bracket, adjustable panhard bar and torque arm. so the big question is what springs to raise the car back up some that are going to handle good on the street and be ok on the strip?
I'd you like the way the car drives now then get the cutout fixed and tucked up better, I'm on strano springs and have a cutout and dont have issues scraping at all with it, but mine is tucked up.
If you just want to swap springs then go back to stock, they handle pretty good as long as you have good shocks.
LS1TECH Sponsor
Mine are about as good riding and not slammed as lowering springs get. If that's too low, then stock springs are the answer, not other lowering springs.
And yes, the Koni's will work with stock springs, and it will handle ok, but not like it does with springs.
Sounds to me like the exhaust just doesn't fit that well.
__________________
