Lowering f body questions.
I am aware that they are called coilovers. I said that some of the PARTS I need are called strut mounts and strut bellows!
I'm not even using that mechanic, he is just one I talked to, so yes I'm getting second opinions.
I wanted to know if it is a common thing to replace all of the control arm bushings...i understand you said the rear one was most likely bad
I have no creaking in any of my suspension parts, which is why I'm hesitant to change the control arm bushings....but if it's not too much money I will change them anyway.
I am changing upper lower balljoints, inner/outer tie rod ends, springs, shocks, upper mounts, bellows, insulators....adjustable panhard bar. Is there any thing else I'm missing? Bearings or something? Thank you
Fine someone called it a strut mount (it isn't)
It is very common to change the front LCA rear bushing. The design is not so good and they tear / de-laminate / degrade over time... and not a long period of time in some cases. I don't think you will hear any noise. The rear bushing is called the "ride" bushing so it is not that high of a rate as the other bushing takes more of the load.
Your top mount and bellow, I don't know about their condition. Mine were perfectly fine when I removed them. I can only speak from my experience. If you want to only replace the worn out parts it isn't possible to know until they tear into it.
Mevotech or dorman?
Im actually thinking buying all 4 lcas with balljoints and bushings installed might be the best option to save on labor.
The balljoints and bushings wont be moog though.
Do the upper shock mounts and isolators need to be moog or can i go with a cheaper brand? It seems like they are not as important as far as wear goes. I could be wrong though. I can get ebay brands of mounts and isolators for half the price of moog.
Mevotech or dorman?
Ill have to check that thread out.
Rockauto has a set of 4 Mevotechs for $230 shipped.
Moog balljoints and bushings will be around $200.....plus another $150-$200 in labor to install them.
So yeah, if the mevotechs are good, i think i'll go that route. Then i can sell my old control arms for a few bucks locally.
#34
You may want to consider buying a GOOD ball joint press for yourself. It would probably run you around $75, or so, but they can be used to R&R ball joints, control arm bushings, and universal joints. I bought one about 35 years ago, and it was worth every penny I spent for it.
#36
However, it's your car, your money, and possibly your safety. I'm just trying to offer some advice...............
#37
LS1Tech Premium Sponsor
We use ProForged balljoints in our arms. Top quality, greasable and reasonably priced. They will run you about $140 for a full set of uppers and lowers. Bushings though I would go with Moog. I would be wary of the complete arms that are the cost of just the good balljoints. I have a feeling they will not have the same service life and quality of using good components in your stock arms
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
#39
We use ProForged balljoints in our arms. Top quality, greasable and reasonably priced. They will run you about $140 for a full set of uppers and lowers. Bushings though I would go with Moog. I would be wary of the complete arms that are the cost of just the good balljoints. I have a feeling they will not have the same service life and quality of using good components in your stock arms.
I've been trying to get that message across for a while, but many people are more focused on price, than anything else.
After I retired from full-time work, I worked part-time, for several years, at a local Advance Auto parts store. When it came to suspension parts, we carried two lines, the 1st quality Moog parts, and the generic, house brand parts, that came packaged in white boxes.
We generally sold the Moog parts to the people who were interested in performance and longevity. The "white box" parts generally were sold to the used car wholesalers, who needed to replace a TOTALLY shot part, and just wanted to get the car drivable for the length of the warranty they provided with the car, usually 90 days.
I'll say this, I personally have zero experience with the Mevotech or Dorman control arms. HOWEVER, in a price driven world, when their complete control arm, with ball joints and bushings already installed, sell for just a few dollars more than a single Moog lower ball joint, you have to know, that something has to be second rate............
